Action: When Done Playing problem
You open a Captivate project file by importing it to the time line in Flash 8. This also worked in Flash 2004. Never said I opened the Captivate file.I am not sure what you meant by controlling the Captivate file from Lectora. Especially that, by that time it is a Flash file and Captivate no longer matters. Although some what limited when can control Flash files from Lectora. Luckly I do not need it to do very much.Captivate is very limited in its ability to add scripting and even the Adobe team will tell you that. I would like scripting during the play of the Flash file created in Captivate not at the end.
