Action: When Done Playing problem
April 5, 2007 12:00 AM
Here's the reason action takes you to the next page immediately - because the action is functioning correctly.Captivate files are a series of "individual timeline slides" that are flattened when published to swf. When the last frame of the first slide is reached, and before the second slide is loaded, the Lectora onDonePlaying function is called, and you move to the next Lectora page (or whatever action is called for).There is a company that sells an extension to the Lectora program that let's you completely control & communicate with the Captivate file, even pass native Captivate testing results back to Lectora. Unfortunately the name of the company can't be posted here as it is automatically removed - regrets.Edited By: Lex_Tensions on 2007-5-18 16:4:46
