A bit of an issue with multiple (SCORM 2004) SCO's
February 13, 2013 12:00 AM
It's been a while!
Here's some background info:
So we are using Lectora to launch multiple SCO's, each course has 4 SCO's:
- SCO number 1 is a standard 'CBT'* course (back and next buttons, etc) with standard lectora javascript.
- The other 3 SCO's are made by lectora and launch content from somewhere else for a 3D course (picture an xbox game but for learning) with custom event handlers etc so only certain CMI data is sent appropriately (everything in regards to these 3 3D SCO's works fine).
The problem:
We have two symptoms of one problem with our LMS or perhaps more acurately the way Lectora is interacting with it and they are best described as follows (*pretend you are the user*):
- So you're in the LMS, the SCO menu with the 4 SCO's is available on the left of the screen 100% of the time, you have to do SCO 1 first BUT upon clicking on a '3D SCO' (IE: SCO 2, 3, or 4) the whole LMS shuts down.
- Also: upon exiting SCO 1, the whole LMS shuts down the same way (not just SCO 1). So, then if you go back to the SCO 1 after opening the LMS again you are stuck on the last visited page in SCO 1 and on an infinite loop of the LMS closing whenever they exit the first SCO, or by clicking on SCO 2, 3 or 4 from within SCO 1.
* 'cbt' SCO = 'SCO 1'.
Further info:
- Note: Between SCO's 2, 3 and 4 this is not an issue and they work perfectly fine and are navigable.
- When we make all our SCO's purely Lectora based (and get rid of our custom stuff), we have this problem with all 4 SCO's.
Alright, I'm not too good at explaining things, and I'm sure I haven't given enough information, but hopefully somebody who has experienced this can understand what I'm getting at. I am more than happy to answer any question of info I'm sure I've left out.
Thanks for reading.
-c
Discussion (1)
It sounds like the Lectora Online course is not communicating properly with the LMS. What LMS is it? Can you send a sample title to support@trivantis.com and reference this blog post? Sounds like something we should get figured out.
