Zoomify output from Photoshop CS3 and Lectora
Notice how you can't view the zoomify swf without the html file. The magic is happening between the tags. If you use that as an external HTML object, modify the directory paths as needed, and include all additional files under Lectora's Title Properties... It may work.Notice how you can't view the zoomify swf without the html file. The magic is happening between the tags. If you use that as an external HTML object, modify the directory paths as needed, and include all additional files under Lectora's Title Properties... It may work.
