Where does Lectora store data between sessions?
Hello,
I'm publishing to a single executable file which has a variable whose value is set to be retained between sessions. I would like to remove the stored value or reset the variable manually outside of Lectora between sessions for debugging and testing purposes. Where does Lectora store the data. For that matter, where does Lectora store data for HTML-based courses when the "Include Title Manager Frame" is selected (I know that by default the data is stored in a cookie)?
Thanks.
