Volume controls
Well, that works if the sound is the same on every page. I think his audio is different on each page. You can't have title level buttons or actions affecting page level objects. But you are on the right track. What you do is have a single title level audio button that is set to not play. Then one each page instead of including he audio as an object, you have a page level action that On Show changes the contents of the title level audio object to contain the audio file for the page. Then the global buttons should work fine. You may have to delay the On Show - Play action 1/2 a second so the page level action to install the new audio file has time to run.
