volume control on media controller skin
November 3, 2016 12:00 AM
Hello,
Does anyone know how to get the volume control to display on the standard controller skins. I am using the built in "Blue" skin. Two weeks ago there was a volume control that displayed when hovering over the mute button. Now there is not. I am figuring I turned it off in-inadvertently. But I can not find anything in the documentation as to what I may have done.
Thank you
Discussion (11)
I am using the controller for audio mp3 file. I have created these files using the same software so don't think this is the issue.
I just tested a video with the Blue skin and was able to see the volume bar when publishing. Could it be because your video file isn't MP4? Can you try converting it if not and seeing if that helps? When you view the content what browser and/or LMS are you in?
I have tested in both edge and chrome....same results
I'd submit a ticket to the Support team unless someone else is able to replicate the issue. You can contact them by selecting the "Submit a support ticket" button on the right hand side of the page or by going here: http://trivantis.com/contact-support
Tim is correct. Change it to "initial" and your volume slider will show and in a short few tests it did not have detrimental effects on the money tab interaction. It uses it to hide the overflow on div's (its tabs/buttons).
Do you happen to know if I can edit this file, and get both the Money Tab and the volume slider to work? Do you know the function of this html code for the money tab interaction?
So change the name to initial from overflow?
The money tab interaction includes a CSS file in the html extension "Overflow". This CSS prevents the volume slider from being displayed.
Tim
Thank you Tim and Darrel. Seems to work fine.
Thank you Jennifer. I will submit.
I have investigated further and determined that the volume control is not working whenever I use a specific LearningBrothers page interaction template called Money Tab.
Kind Regards, Laurel
