video flv problem
January 5, 2009 12:00 AM
Hello. Don't know if you've gotten your problem resolved or not but I ran into the same problem. Re-check the layering of the video on the page and make sure in the Properties part it says Initially Visible and is not layered underneath another object.Hello. Don't know if you've gotten your problem resolved or not but I ran into the same problem. Re-check the layering of the video on the page and make sure in the Properties part it says Initially Visible and is not layered underneath another object.
