video flv problem
Would seem to me that 2 problems are mixed up here. At one side we have the "FLV will not play" issue, while the other one must be "JWC flv player is not commercial".To put it straight, we simply cannot fix issue 2 for you. That said, is this not up to the browser? Lectora is simply a program to build content and publish it to the web. Whatever the user has installed thereafter plays the video, not what you intend to use for creating or viewing it.For example, I regularly use simple flash animations in the courses we build. I always publish the SWF files to Flash 8 or higher. If someone views our courses with Flash player 7 installed, the animations will rarely work. No matter what I do before publishing, the flash file will not play.This means that you should install JWC on every client computer that displays this course in order to make it work. I do not know of any internal settings in V09 of Lectora that might fix or support this.
