Variables using title level targets
112MB!
I downloaded it but when Winzip tries to open it I get a msg that it is not a valid archive file.
Usually it is better when you are having a problem to create a small title with just the pieces that are giving you fits. Maybe even with little or nothing on the pages. In your case might be a 5 page file with mostly blank pages. Then put the code in that is not working for you so you can publish it quickly and know just where to look.
Alternatively you can copy the folder containing the course, delete a lot of the "heavy" pages and try again.
