Variables using title level targets
December 2, 2009 12:00 AM
So I took a look at this. You are setting the variable on the click of the text object, however, you never activate another "show" action after that setting. The show action that you have as the first action in your title, should be set as "on: timer .5"
Also, in the object pane, move all of your inactive graphics above your active graphics. Your go button is showing, but your inactive graphic is at a higher level, so the active Go button can't be seen.
Or this is what I found from the small program you uploaded.
HTH
Dwayne
