Variable not working after published
I created a training game, and when the course opens I want music to play. I set a variable on the music so when it's done playing it will modify the variable. On the main screen, the user will select a category. After a category is selected, it goes to another page, it will then show the answer, then we return to the main category screen. When we return to the main page, I set another variable that if the flagged variable on the music is true, then to NOT play the music again. Works fine while testing it, but after published it does not. Any better suggestions on handling this?I created a training game, and when the course opens I want music to play. I set a variable on the music so when it's done playing it will modify the variable. On the main screen, the user will select a category. After a category is selected, it goes to another page, it will then show the answer, then we return to the main category screen. When we return to the main page, I set another variable that if the flagged variable on the music is true, then to NOT play the music again. Works fine while testing it, but after published it does not. Any better suggestions on handling this?
