V9 Web 2.0 Popups and Enter Key in Test
I just recently upgraded to Lectora version 9 and I'm investigating the new Web 2.0 popups. I've always included a custom action on tests enabling the user to use the “Enter” key to “Go to next page.” It appears that in version 9, this functionality is built-in. I was getting double popups for a bit, but now, I’ve removed my action and it works as expected. The problem is that after pressing enter, the feedback shows up, but pressing enter again (which normally is the “OK” button on a regular popup) shows a new-but-empty popup. “Enter” can be pressed a bunch of times leaving a cascade of empty popup windows. After closing all of them, the original popup can only be closed with the 'x' in the corner or a JavaScript error occurs. It seems like the dialog itself doesn’t respond to the enter key, but instead thinks a new dialog should be created. Is there a way around this? I’m looking into customizing the JavaScript myself to see if I can add a focus on the popup button, or setting a variable once a popup is opened to prevent an additional popup from being created. In the screenshot below, I've added red boxes to hide our client's name.Kenny Della ValleProduction ManagerConvergence Training360.834.0991 x221kdellavalle@capstonetechnology.comwww.ThinkConvergence.comwww.MSHASafetyTraining.comEdited By: kdellavalle on 2009-2-17 17:40:9
