Using the element to display PDF
*** Update to the post on iFrame and PDF ***I had previously talked about using iFrames to insert PDF documents(See previous Post).I have come across another method using the element to do the same thing. See website Code: Using External HTML object:
It appears your Web browser is not configured to display PDF files. No worries, just click here to download the PDF file.
You can also use percentages for the width and height. This is using the method like we do for Flash files.Regards,
