lpro65,You can also use test questions, just make the question's weight worth 0 points. Now you can give the questions a bogus answer and if the user answers it wrong, it will not count against their score. If all quesitons have a weight of 0 in the test, the student will simply get a 100% pass for answering all of them.Using a test has certain advantages such as being able to require that they answer all of the questions and you can span it across multiple pages. It really depends on what you are trying to create whether or not to use a test or a form to do the survey.
