@etav
March 15, 2012 12:00 AM
Hi,
I need to get lectora to either set a variable or call a method in my flash file
I'm a flash developer and I've searched for this problem on this forum but could not find a solution/response.
I have attempted to use the 'set variable' flash command in Lectora and it does not work. However, the 'go to frame' flash command works fine.
Has anyone else had any issues with the 'set variable' flash command? And if so, what is the best solution?
I'm using AS3. The parameters work fine. But I need lectora actions to trigger 'set variable' or public methods in my flash file during runtime.
Hope someone can help me.
Ewan
Height/size of an external HTML Object
Creating flash media objects
