Hi ppl,I have been thinking of how to incorporate flash animations as transitions into Lectora SCORM elearning courseware.I have been searching around, and it seems the 'Done Playing' function isn't working properly as yet. So the next solution I can think of, is coding directly in flash, using javascript to direct to the respective pages of the courseware.However, I face this problem. Whenever I publish as SCORM in lectora, the pages naming has additional numbers added to the url string. Can anyone advise me on how to capture the value? If I can capture the value in lectora, I would be able to pass the variable value to Flash. And it would then be workable.Thanks in advance:)
