Using Flash with Lectora SCORM
Are you making a flash menu? Usually if I don't want to worry about what the pages are called I will create an action group on the page and put a goto action in the action group that points to the page I want. Then, from flash I use javascript to run that action group - that way it doesn't matter what the page gets called as long as that action group is pointing to the right place in Lectora. Does that help?Are you making a flash menu? Usually if I don't want to worry about what the pages are called I will create an action group on the page and put a goto action in the action group that points to the page I want. Then, from flash I use javascript to run that action group - that way it doesn't matter what the page gets called as long as that action group is pointing to the right place in Lectora. Does that help?
