Using Flash Command
July 4, 2007 12:00 AM
Hi,I’ve got a question for people that use Adobe Captivate in Tandem with Lectora to create courses. I did an exercise with Captivate (a simulation where the user select a value under a list and push a button to validate) (I choose to export result in SCORM), I add the flash under Lectora and add an action "Flash Command". But Now i Do not know what should i write in Flash Command to synchronize variable (Scorm) use in captivate and variable in Lectora.Someone know what is next step ?I will be very happy, if someone has got a simple simulation sample with captivate and Lectora in tandem Thank’s for your help Xavier
