Using Flash Command
I've got Lectora 2007, I saw that I shoud use Flash Command to communicate between Lectora and Flash Movie, but I do not know how to use it. In fact I trying to do this simple thing:In lectora : 1 question Yes/No (1 point if it’s good answer)In captivate : 1 question Yes/No (1 point to if it’s good answer), I choose to export result in ScormFinally send the result to my LMS (2 points if both answers are right)In lectora, I use Flash command but know I do not know what Parameters I should use to tell in Lectora to get the scorm score from Captivate and Add it to Lectora variable used to send to the LMS.
