Using audio files as flash objects
In the funtion, you need to have single quotes around the new variable value.You could try something simplier like this:getURL("javascript:VarmyAudio.set('1')"); Also make sure that you are referencing the Lectora variable 'myAudio' on the page your flash is on using a Lectora action. (Could be as simple as on show, modify variable, myAudio, [leave value blank], type: add to variable)BTW: you can leave out step 3. There is no need to have javascript code to get the new value. Lectora will update the value automatically as soon as the set() function is called.Edited By: aaron on 38562.7558217593
