Using audio files as flash objects
thanks for your reply Aaron,here is what I did:adjusted the flash function as you suggested to:getURL("javascript:VarmyAudio.set('1')"); in Lectora ( actually I am using Saba Publisher 4.1),I declared the myAudio variable with '0' value.then created an action:on show >> modify variable >> myAudio>> [blank value]>>add to variable.>>submitted the value of myAudio to the textbox..when tested, myAudio still retains 0 when I clicked the flash button. any suggestions why? ( the codes are pretty simple...)other scenario - if I use on show >> modify variable>>myAudio>>javascript:VarmyAudio.get> >set value the value of myAudio would change to '1' on page load, not on a click ...
