Using audio files as flash objects
As long as you have a Lectora action on the same page as your flash movie which references the variable, Lectora will add code on the page to declare this variable. You should be able to grab its current value using VarmyVariable.getValue();As long as you have a Lectora action on the same page as your flash movie which references the variable, Lectora will add code on the page to declare this variable. You should be able to grab its current value using VarmyVariable.getValue();
