Are you caputuring variables created by Lectora or User Defined variables created by yourself using the Form Object and elements?All Lectora variables are prefixed with a 'VAR', so if you were attempting to capture the students result to Question 10 and it had a variable name of Question10, then to acquire the value you would look for VARQuestion10.Edited By: InsTrainer on 38639.4665509259
