Using ASP to Capture results from a Quiz
Has this issue been resolved? We are also having a similar issue. We have five Lectora courses with a test and survey for each course. Both the test and survey are each configured to POST to asp files.The problem is that not all of the variable data is always being captured. The user defined variables are captured, but the Lectora variables are not always captured. We are using the Lectora test function for both the test and survey. The courses are designed to retain variable values between sessions. However, data can still be lost when users complete in one session. We're not maxing out the 4K cookie size, although data for all courses in being captured in one cookie. Why would Lectora not consistently be capturing data?The survey has two pages, the NEXT button on the second page of the survey is configured to submit score. Data is consistently captured for page two, but only intermittently captured for page one.Any suggestions?
