Using ASP to Capture results from a Quiz
It gets stranger... I've tried to capture each variable output from the quiz as a separate variable (i.e. reading in Question1 into a variable, then question2 etc...) and it all works up to question9, but fails after that! Is there an issue with ASP that only allows a certain number of character to be sent across, or am I just missing something else entirely? Any suggestions (however obvious you may think they are) would be welcome.
