turn off lectora audio from flash
You should be able to code a stop action on the Flash button for the Lectora audio file. If you click on the Lectora audio file to see the properties it will give you the file name (i.e. audio9054). If you have the file folder location for the Lectora audio, you could use a stop command directed at this particular audio file.Let me know if this works for you.JohnPS In order to see the Lectora file names, you need to have the "Show HTML published object names in object properties" checked. You can find this on the General tab of the Presferences.
