Hi,
I'm trying to build a mute/unmute button in Lectora that will call a function in a swf movie to toggle the sound off and on.
I used the action Flash command and set command to call function.
l was able to get this feature to work when I'm using AS3, but I get an error message (Object doesn’t support this property or method) when the swf movie is coded using AS2. The error occurs when trying to execute "anim282.flsPlayer.toggleSound( '1' ); ", this seems to imply the linkage to the flash movie is incorrect.
The big problem is that I really need to use AS2, targeting flash player 8.
Does anyone understand why this isn't working, or have an alternative to achieve the same effect?
Thanks
Dave
