Hello sbrooks.Would it not be better to create the transparent buttons within Flash as well and place it on new layer and positioned in front of the animation? Set it to show for 2 seconds after it begins to play. Then in Lectora, insert the animation,with the Auto Start not checked. Add an action to the animation with the following properties.On: Mouse ClickAction: PlayTarget: [Name of the Animation]Now your transparent button will be displayed. The drawback will be that the user will see the mouse change to a hand over the entire animation but at least it will play.Regards, Edited By: bruman on 2008-4-11 16:29:30
