Translation tool problem
Have not had the problem but if I did I would translate it like this. Suppose you had "Click here for more info" to translate as a link. I would replace first replace the letter from the second to the next to last = "lick here form more inf" and then replace the C and then the o at the end. This might keep the link from being destroyed. Try in a test page.Have not had the problem but if I did I would translate it like this. Suppose you had "Click here for more info" to translate as a link. I would replace first replace the letter from the second to the next to last = "lick here form more inf" and then replace the C and then the o at the end. This might keep the link from being destroyed. Try in a test page.
