Hi Is there anyone that can help us, with the problem that we are facing when we want to translate a course that we build.In the course there are links that we added through the option 'add hyperlink' when you select a word and right-click on it. These links refer to other pages in the course.When we export the course to a rtf file, the links are shown in the rtf file. When we change the link names and import rtf file into Lectora, the link doesn’t work anymore. Has anyone a solution on what is causing this problem?
