Transitions Problems on Multiple Uses
July 25, 2007 12:00 AM
I solved this for myself. I guess that I should have tried a little harder before posting!The problem was that the location gets mangled when an item is shown in the HTML version. Creating an action group to handle the display worked. The first action sets the X&Y values to those of the final location, and a second action toggles the visibility. All works now!As an aside, is there any easy way to set the X value of an objects position to be equal to a variable's value?
