Transitions Problems on Multiple Uses
I have a "Course Map" designed as a group of object including a TOC. It has in and out transitions to make it slide in/out to the side of the screen. I have a button to toggle the display that has an action set to toggle the visibility state.in HTML publishing ONLY...Everything works fine the first time it is revealed and hidden, but after that any future attempts to show the course map fail. It just doesn't appear. This problem does not manifest itself in an EXE publish of the same project.Any ideas for a workaround?I'm using Lectora 2007 SP2a.
