Transitions and Audio Syncing Lectora 12
March 24, 2015 12:00 AM
Hello,
I'm not sure anyone has noticed but....
Lectora 12 transitions are in seconds, just seconds.
The audio sync is in minutes and seconds. Please just pick one method or the other, its like having one in inches and the other in centimeters.
Half the time you forget to convert so after you've synced all your text to the audio in minutes and seconds, you decide to transition in an image at 1:03 and end up typing 103 seconds instead of 63.
Thanks,
Discussion (1)
I think "feet and inches vs inches" is a better analogy here :)
