TOC Icon issues
when I publish the title to html, the Table of Contents, (either the css or js or html file), tries to look for the toc icons in a non-existent "image" folder; in other words, all of the icons and images used in the title are in the "image" folder in the same directory that the rest of the files are generated in - the wave files are also in their "media" folder, etc. When I start to run the title, the toc shows up with X filled boxes instead of the standard icons - when I right click and look at properties, the path shows a non-existent "image" folder, not the one it should show where all the images are stored - the next and back, etc buttons are in the same image folder and they show up fine as well as the images we are using in the presentation - they all show up fine - its just the TOC icons - What do you think the issue is?
