I've noticed a problem with layering text over a graphic in the 2007 version of Lectora. When updating some 2005/2006 version modules I found that the text is no longer shown on top of the graphic when published.After testing a bit I found that if "Render text as image when published" is checked in the text property dialog, the text cannot be seen in the browser (IE 6) if it overlays a graphic.Is this a known issue? Anyone else seeing this?Thanks
