text box sizing
April 4, 2016 12:00 AM
My text boxes look like they resize appropriately for the various devises. But then I view them outside the editor or in reviewlink and the background color is still in the correct place, but the text continues outside of that "box" and on off the page. Ideas?
Discussion (7)
What browser and version are you viewing the course in?
I have tried it both ways with the same result. Problem started with using scroll bars for phone and you when I select to use scroll bars, the wrap text option grays out. So I thought wrapping was assumed with scrolls.
And to add to the confusion. The text is continuing below the background fill too. So that isn't a wrap issue. ???
I will send you the files so you can take a look. I dealt with this by redoing the pages and the newly created ones work. That means I can meet my review deadline but I would still like to know if I did something incorrectly so I won't do that again. I think it has something to do with when I selected the scroll and wrap options. Strange that I could create new pages, but not edit the old ones to do the same thing.
Are you able to share the files? If your not comfortable putting them onto the Community you can send them to my email (jennifer.valley@trivantis.com) and they won't be shared with anyone except our support and possibly product team if I can recreate the issue.
