Test Language options Help
I've been working on a set of courses originally built by somebody else. For the Client we need to take these courses and translate them into French and I've hit a few snags that I'm not sure how to fix revolving around the Test's that are in the courses.
First when somebody clicks on the next button without answering a question it pops up with the English text "You must answer all questions to continue." and I'm not sure where to edit this to be French. As well this happens when you try and exit the course.
Next this course has Test results generated at the end of it and it will list the "Pass, Failed, Your answer, correct Answer." in English. I haven't found a way to change these to be french.
Does anybody have any ideas? Is there even a way to change this.
