Test inheritance problem
For some reason, a test that worked fine before I upgraded to v11 no longer displays properly. When I view the test pages within Lectora they look fine, but if I preview in browser, or look at the exported html, the pages go crazy.
There seems to be some issue with the inherited properties. If I choose to inherit no settings, the pages display fine (but, of course, without my page navigation bar and background, etc), however if I inherit even one innocuous setting, the whole things goes nuts and nothing is displayed properly (can't even see the page content).
Any advice?
Discussion (1)
Update:
I tried setting the test to inherit nothing, then copied all of my title settings to the test. In doing this I discovered that the source of the problem was one of my title-level tools that for some reason doesn't play well inside a test. I removed the tool and now everything is working.
However, this does not explain why the test does not work when I inherit just the basic title-level properties (navigation bar and background image).
