Test Contents Not Displaying
Basically what we found is that if you enter a test that has sections using randomization using something other than Next page, you need to have a "Welcome" page at the beginning of the test BEFORE the sections. If you just GoTo the Test chapter, all you get in when published to HTML is a blank screen. Instead, have the GoTo specifically point to the first page after the chapter. We did not try just adding the page and still letting it go to the Test. That might have worked too.Basically what we found is that if you enter a test that has sections using randomization using something other than Next page, you need to have a "Welcome" page at the beginning of the test BEFORE the sections. If you just GoTo the Test chapter, all you get in when published to HTML is a blank screen. Instead, have the GoTo specifically point to the first page after the chapter. We did not try just adding the page and still letting it go to the Test. That might have worked too.
