Technical Details For CGI Submit
Hello Angie.Let me address the cache file issue. I once had a situation where I had made some changes to some training I had, but the changes were not being reflected. In speaking to our IT support, they suggested to me that maybe the cache files on the server needed to be cleared, and once they did that my changes were seen. I am referring to either server. Again working with my IT support people was a first step in finding a solution.I believe that the max in cookie size is 4k. Hence if your info is greater than that you will be losing some information.As to the first issue, that I do not know why this is occuring. Anyone out there with 2007 and sending .asp data could respond?Regards,
