I need to use WMA audio format for Lectora 2007's Audio Editor. I have two methods:1. There is a very inexpensive software called Smart Audio Converter ($19.95). Don't bother with the trial version - it will only convert 60% of the file. Use Audacity to deterine your timing points.2. There is a streamlined version of SoundForge ($54.95). You can convert your audio to WMA in there. When you save your WMA within Lectora's Audio Editor, you can see the markers when you open the WMA within SoundForge, as well as adjust them. Lectora will recognize the revised marker positions when you save in SoundForge. You can also insert markers in SoundForge.
