You can use free Windows Media Encoder to convert the audio file from mp3 to wma. Then bring the wma audio file into Windows Media File Editor (an application that is included with the Windows Media Suite) You want to click on the Script Commands button which allows you to add script markers. Add, name and then arrange the script markers on the slider bar where you want the actions to occur. Save the file.Import the wma audio into Lectora. Open the Events tab and use the dropdown to find your event(s), apply your actions and targets as needed.You may then right-click on the audio object on the screen layout or the speaker icon in the left-hand panel and select "Convert to FLV". Assign player skins as desired and you're set.
