We are running into an issue where the max size of the suspend data is getting reached. I noticed all the answers in our course are getting stored in the suspend data. Is there a way for that not to happen, and just write the response to the LMS. My understanding is that everything with a variable name is stored as persistent data as name/value, and will be in the suspend data.
For publishing, we have checked off "The published course will be report "test/survey questions interactions to the LMS"
For each question set, we are using the action "submit/process test/survey"
On another note, what is the difference between:
1) Process Question
2) Submit/Process Test/Survey
3) Submit Form
