I have created a survey in Lectora and was able to publish to coursemill without a problem. When running the interaction report in Coursemill, I am only able to see the results of the short answer survey questions. All other likeart questions are showing a 0 for the answer. Is this a problem with a setting in Lectora or Coursemill?In addition, can you create a survey and make it anonymous and still report it to Coursemill?
