Survey results not reporting to Coursemil
Make sure you have checked the "report Interactions to the LMS" box on the SCORM Options tab when you publish from Lectora.Make sure you have checked the "report Interactions to the LMS" box on the SCORM Options tab when you publish from Lectora.
