Survey formatting problem
This is my first project with Lectora. All went pretty smoothly, but my survey is a mess. When I publish, all the formatting is gone. THere is no background, no css. It's just three survey questions, badly laid out on the page.
If I publish using the javascript option, I get the error that I can't send survey data via email. I get that, but I don't know how to use the CGI option.
If Lectora uses Java to publish the surveys, is Java my problem? My test displays just fine, but it does not submit results at all, so perhaps it doesn't use Java.
I've searched this forum and online and haven't found any report of a similar issue. Thank you for any help.
