Suggestion: Make Audio Work
If you put an audio clip on a page in 17.1.1 or 17.1.2 then no actions will play whatsoever. None. i can't get actions to sync to the audio nor will any other actions fire. VERY bad.
Discussion (1)
Can you provide screenshots? Are you still experiencing problems?
