stop advance if question not answered
Thanks Ben! As always you're a big help. there will be quite a bit of rearranging if i were to put everything inside a test so since there's only 34 questions, i'm going to go with the seperate next button. :)Thanks Ben! As always you're a big help. there will be quite a bit of rearranging if i were to put everything inside a test so since there's only 34 questions, i'm going to go with the seperate next button. :)
