Static audio when published
June 4, 2013 12:00 AM
Has anyone run into an issue, where only once published does the audio sound like static?
I ran it within lectora, and my narration for the slides work perfectly, but as soon as I publish it all of the audio turns into this horrible static when played!!
Discussion (1)
See if compression is enabled in Publish settings and disable it.
